rogerthebodger
If the sender is 3 wire you need a supply voltage onto the + and - connectors and the measure the voltage between the - and the 3rd wire colours I don't know
This will need the meter set to the 20 V dc in the white section of the switch
If its a 2 wire sender, you setting will be ok to see where the is on and off as the sender rotates
