paul salliss
The glass window percentage in a modern hull is creeping up and up, I look at it and assume it's a weak point to the structure, do people agree that this aspect has gone too far
Yes I would have thought so.....theses days ?I imagine design has evolved over the last few decades from educated guesswork to 3D design and modelling . The designers should be capable of understanding stresses and deflections in a much more sophisticated way than would have been possible in the past.
It’s because we are off .....leaving this plague ridden , statue less, rioting island , tomorrow.You're in fine fettle this morning Porto![]()
I do.The glass window percentage in a modern hull is creeping up and up, I look at it and assume it's a weak point to the structure, do people agree that this aspect has gone too far
There was an sc42 on the hard by us for 6 months waiting for a screen .Say you have a 10 year old boat, no longer a production model and you catch the corner of a pontoon, or a lock wall or someone manoeuvring in their berth hits you with their stowed anchor. With a glassfibre, aluminium or steel boat this will result in a nasty scratch that has to get repaired in the winter, all doable but you can continue with your journey safely.
On the other hand if you have large bonded in windows in the hull and this is shattered, you cant put to sea and its not even rain proof.
Its now a specialist job to replace the window but only If...................You can get one off the shelf! Or is it available to order and if so what is delivery say 3 months?
What about if you can't order one as previously said?
I suppose you could use a sheet or two of 15mm plywood, 500 Spax self tappers and a case of Sikaflex?
Sorry for me I go to my cabin for sleep, to shower, change my clothes or for recreational purposes none of which requires huge amount of daylight or an audience.
Give me small recessed portholes or windows, mine are about 18 inches by 8 inches and recessed 3 inches in from the hull, could block that up in an emergency.
Is the guy on the hand held saying , be tender with me.
Ahhh framed Windows, another thing of the past.....sadlyI do.
NOT having any glued glasses anywhere was one of the boxes I wanted to tick, during my last boat search.
Which is one of the reasons, albeit not the only one, why I ruled out Azimuts, for instance. Or any Ferrettis after the 57.
It's something that seems to sell boats though, particularly to newcomers. Up there with the joystick, as I understand.
Not that I'm complaining - far from it: as long as this contributes to the low demand (hence reasonable prices) of used boats with mechanical throttles and framed windows, that's fine with me!![]()
I foresee these boats being like the A380... scrapped at 10 yrs old...Glass can stay bonded in a fibreglass car for at least 30 yrs. The bonding is covered with trim so uv effects are not are problem.
If boats use laminated then the bonding film can block over 99% of the uv rays protecting the adhesive and your interior.
It's the user some years down the line that may have to contend with issues.
On the plus side you must get a great view from your bed ? ?
