PaulRainbow
The supplier is talking rubbish Nigel, i would not deal with him.OK ... thanks ... looks like a winner ...
Oh - he sent this after :
"That is, if you have several different batteries on board, they must be charged separately!"
I replied :
"Hi Yury,
The Victron I have – has 3 separate charge outputs .. (my boat)
Output 1 is charging 75Ah Lead Acid as my engine start battery.
Output 2 is charging two parallel 75Ah Lead Acid as my services / domestic power
Output 3 is not in use – but would also be Lead Acid unless I change all 3.
The only rule is that when type of battery is set on the Victron – that type is for all 3 outputs. The size (Ah) can be different on each output …
Nigel"
