pcatterall
Thanks to helpful steers by forumites my BM1 is now reading discharge as discharge and not charge ( the advice was to ensure that the negative lead was attached the end of the shut away from the battery)........thanks guys!!
The issue I have , now I can measure it, is that when switched on the unit is using 1 Ah even when nothing is running.
The fridge cycles off for 15 and on for 5 minutes, when 'on' the consumption is 4 amps but still an amp for the 'off' period' This indicates a lot of wasted juice. Is this normal?
I guess that I could time the unit to come on for 15 minutes every hour or is there some cunning trick I could use?
