coveman
I am considering using Trilux on my outboard motor as an antifoul after priming , but I do not want something that erodes easily and makes a mess when transporting the engine. Any other users out there ? Does it dry hard?
Yup! Won’t rub off in normal handling.Does it dry hard?
Probably using it in sea water![]()
It useless as an anti foul.I am considering using Trilux on my outboard motor as an antifoul after priming , but I do not want something that erodes easily and makes a mess when transporting the engine. Any other users out there ? Does it dry hard?
It works OK on my saildrive and propeller but my boat is in Portland Harbour which doesn't suffer as much from fouling as other places.Yes, the reason for wanting to anti foul it is that it will be kept in the well of my boat with the leg submerged and the well is not really accessible enough to use a bag or something similar. I was hoping to then leave it in situ for the summer season. In the past I have taken it out each time and stored it in the cabin - something I was hoping to avoid now, and hopefully reduce the stress on my back!
I'm now questioning this as from the replies it sounds as though it does not work too well?
Mine is in Weymouth council marina now - used to be in Portland Harbour!It works OK on my saildrive and propeller but my boat is in Portland Harbour which doesn't suffer as much from fouling as other places.
I wouldn't be put off. It's often a good idea to read the makers instructors before applying it.I'm now questioning this as from the replies it sounds as though it does not work too well?
Try velox then. Can be hard to get hold of but worth the effort. Can be used on the prop too. It’s a leap better than Trilux, however it is applied…….Yes, the reason for wanting to anti foul it is that it will be kept in the well of my boat with the leg submerged and the well is not really accessible enough to use a bag or something similar. Unfortunately the design means the engine cannot be tilted out of the water. I was hoping to then leave it in situ for the summer season. In the past I have taken it out each time and stored it in the cabin - something I was hoping to avoid now, and hopefully reduce the stress on my back!
I use my boat loads and as we have said before they may be differences in oz/Uk formulations.It depends how large an area you want to cover but Velox is not cheap, Trilux is cheap but less effective. Another option, especially as Velox is difficult to access, is Prop Speed. But as with Velox you need to follow the instructions meticulously. Prop Spreed, or Prop One are not cheap either but you will see them on the running gear on MoBos. There is a theme here - money offers the best AF. Prop Speed or Prop One are silicone coatings.
As Skylark mentions - the best way to keep the O/B clean is to use it. The constant flow of water will keep the fouling at bay, whether its shell or vegetation. But leave your O/B idle for a month or so and something will adhere and need effort to get it off (whatever you use as an AF). As soon as you need to scrape you will damage the AF and the damaged area will be where the fouling starts - and more quickly as the AF is damaged or removed completely.
I cannot agree that Trilux is useless - its does have a positive effect - but not enough as most people don't, or cannot, use their boats with sufficient frequency. They then blame the AF forgetting they did not use their boat (or did not follow the application instructions).
You may find you can make a bag with a big hoop as the opening. You might be able to manouver the bag in your restricted well using a couple of poles and encase the O/B in the bag. Add a spoon full of American Bleach inside the bag each time you leave the boat.
There is no perfect answer.
If you have the space - maybe a beam across the well and a block and tackle would allow you to lift the OB enough to remove it from the water, leaving it suspended - and allow you to support your back. A decent chain will allow you to secure it from prying fingers. You don't mention the boat nor offer pictures so difficult to offer any other ideas.
Jonathan
Velox is not very expensive here - £46.95 and now in stock in Force 4 one of our big chandlers - and it the choice of many stinkies including me.
Propspeed by comparison is £200. Now that IS expensive.
And Trilux is useless Maybe yours is better.
