jbweston
I have just dismantled the two Blakes seacocks fitted to the toilet inlet and discharge on my boat. The inlet one was in perfect condition, but the outlet one had some pitting corrosion. This is on the tapered plug in line with the outboard end of the toilet discharge pipe when the cock is closed - i.e. it seems to have been caused by something lying in the pipe against the closed cock.
Has anyone else had this problem and do you know what might have caused it? I'm interested to know whether it occurs with just the sewage, or whether the vinegar and occasional 'Toilet Duck' I use can eat through the bronze.
I've had the boat for just over a year and don't know if the pitting occurred while I have had her, or (perhaps more likely) in the 17 years of her previous ownership. It's always possible someone in the past has used stronger chemicals, for example of the drain cleaner type.
If vinegar or Toilet Duck can do it, then I'll be even more careful to flush them through, although I thought I was doing that already.
The rest of the seacock seems in good condition. This is not general corrosion, and I can't see how it can be electolytic in that position.
Any wisdom appreciated.
