especially if you have a nice big bulb at the bottom....Just a thought. Many older designs had swept back fin keels rather than the modern vertical types. I believe it was thought that swept back fins were more hydrodynamic but later proved to be minimal if at all.
I do wonder if the older style keel would be less damaging if grounded. I was languishing in my boat one time close to a marina sill. An older style yacht charged the sill at some speed and literally rose up in the air. Perhaps a vertical keel would not have fared so well.
That depends, are you certain no damage was done? There are a lot of half sunken long keelers around our coast in rivers and it stands to reason that some have suffered impact damage.Perhaps a vertical keel would not have fared so well.
Interesting. Thanks.Personal experience:-
Sigma 41, hit rock under sail, web at front of keel, flange snapped clean through, significant internal damage to frames, stringers and hull.
Sigma 33, struck rock under power, cracked frames and stringers inside, no damage to keel.
Contessa 34, struck a boulder strewn leeshore under sail, big dent in lead, frames and stringers damaged in hull.
The above all have fins that slope backwards and do not have grids. In general terms, when the keel decelerates rapidly, the hull tries to pivot over the front of the keel flange as well as reacting against a keel driven upwards by shoaling water.
Encapsulated keels can have faired sections that are hollow and if grounded can cause flooding and sinking with no access to void space. Also damage to encapsulated keels, with no hull stringer and frame damage, can expose steel ballast to salt water and corrosion. This can cause significant secondary damage down the line and be a very expensive repair.
All yacht keel styles have inherent risks associated with grounding. I think, like Osmosis, grids and potential damage, will become accepted as a potential issue with second hand, older boats and be routinely reflected in potential buyers concerns. I do not know how much of an issue this is in the second hand market.
I'm not sure what damage was done to the yacht .That depends, are you certain no damage was done? There are a lot of half sunken long keelers around our coast in rivers and it stands to reason that some have suffered impact damage.
I wonder if keels will ever have crumple zones like cars....
