Insurance - again!
syvictoria
12 Oct 2009
Europe
I know that N&G has been discussed a couple of times here in recent months, but my broker is now offering me an N&G policy at renewal due to the previous one no longer being available. The policy that I'm being offered is this one:
N&G Yacht and Motorboat Insurance Policy
I have a couple of concerns, possibly unfounded.
The 'similar' replacement vessel on total loss clause is far from ideal, but I hope that common sense will prevail should I ever find myself in that very unfortunate position. The anchoring clause seems better than some that I have seen discussed on here.
What I'm potentially unsure about about are two clauses under the "What you are not covered for:" heading on page 13:
• replacing, repairing or renewing a faulty part, faulty design, faulty construction or defective materials.
• failure, fault or breakage of electrical or mechanical equipment.
Are these terms considered normal/acceptable?
TIA!
lustyd
27 Jul 2010
Why would either of those be covered under insurance? The first would be a warranty claim with the manufacturer and the second is effectively either wear and tear or poor maintenance.
lustyd
27 Jul 2010
Don't get me wrong, it's a good thing to read and understand the document. I think those exclusions are to be expected though and seem a fair addition to protect the insurer. It's possible that if you call them you can protect against those too in exchange for higher premiums, although I can't imagine much value in doing so unless the boat is very new as most faults will have been found and if we're honest a lot of failures aren't entirely unexpected on older boats :)
Graham376
15 Apr 2018
So what happens if a rigging screw breaks & the mast goes over the side? Do they pay for everything, except the rigging screw?
That's the usual case, they cover the consequences of something failing but not the item which failed. Engine packs up, you wind up on the rocks - damage covered but not engine repairs.
lustyd
27 Jul 2010
Doesn't fit into either category from above unless it's new and has a defect. I assume you're talking about an old, out of warranty one which shows no signs of wear and is a reasonable age. It's not mechanical equipment either so the failure would just be covered under normal bad days at sea coverage :) That's once you show a recent survey or rigging replacement receipt, of course!
Tranona
10 Nov 2007
The typical example here would be an internal chainplate that was hidden so it could not be inspected failed and rig was lost. Rig would be replaced or repaired but not the failed chain plate. In the scheme of things it is usually the consequential damage that is the big cost.
