INEOS AC 2-0
st599
9 Jan 2006
Just wondering if there were a collision at these sort of speeds.
If both foiling, and you clouted the last third of a boat, would you just largely spin them round, as most of the boat is out of the water and most of the impact absorbed ? You would still probably loose the rigs.
NYYC falling from ~2x normal height on to water caused the frame to punch through the hull.
I reckon a pointy bit hitting a flat bit would be pretty catastrophic.
kingfisher
7 Nov 2001
Belgium, Holland
carbon is very brittle. It would be like smashing 2 packs of instant noodles together. Shards flying everywhere.
Kukri
23 Jul 2008
East coast UK. Mostly. Sometimes the Philippines
I think the semis will be close and hard fought. I think we can assume that Ineos will get their Cunningham sorted (?) and will tweak a few other bits before the final.
But I think that in March NZ will have a huge advantage in boat speed They know an awful lot about these sails.
By the way - to settle a discussion going on in my club - is the inner wheel on Britannia to vary the rudder rate from coarse to fine, or does it do something else?
flaming
24 Mar 2004
Nobody seems to know.... And those who do aren't telling.
I think rudder rate is the most likely explanation that I've heard, but I'm not 100% convinced.
Bobc
20 Jan 2011
New foils on ETNZ. They certainly look interesting. Quite small, which should make for good top speed but it'll be interesting to see how much lift it gives them in the lighter stuff.
Kukri
23 Jul 2008
I think those tell us that ETNZ are well ahead in sail technology. I think those foils will be faster but will need more horsepower to unstick and I think the defenders have gone for them because they can control their sail shape better so they will be able to unstick them sooner.
Kukri
23 Jul 2008
I have seen something to the effect that the delta shaped foils used on “Britannia” are used to conceal the hydraulic rams and linkages (there’s always loads of room inside a delta wing) and not because of speed because in terms of Reynolds Numbers these boats are flying at about the speed of a fast glider only. “Supersonic” is still quite far away.
flaming
24 Mar 2004
Yeah, seen similar. If you look at the video I posted above, the suggestion is that the kiwis, by finding a loophole that allows them to have only 1 flap in effect, will only need 1 actuator and therefore have a lot less stuff to hide.
The flip side is that they then need that bulb to make the mass of the foil up to the 921kg that it has to be.
What the Kiwis have now though is a lot of data on the performance of the challengers. If I was their design team I'd be saying "add 5% to the number we saw from the round robins, that's where we need to be". The challengers however don't have anything like as accurate data on TNZ. The 1st beat in March is going to be so exciting.
I await with interest what foils INEOS declares for the Prada final. Those W foils are such a departure from anything the other teams seem to have tried, be weird if they were just a dead end...
In the meantime bring on the racing this weekend, such a great thing to have to look forward to in the midst of a cold, grey, lockdown winter.
Laser310
15 Sep 2014
LR looked good today...
here is a screenshot of the ports starboard protest against INEOS that I got from the virtual eye replay
This shot is at the instant before LR turns up
both boats are going the same speed
it's completely clear that INEOS is crossing ahead
That doesn't mean that LR might not have believed at the time that they should take avoiding action - just that in the end, with the knowledge provided by this kind of data, Screenshot (19).jpgit wasn't needed
anoccasionalyachtsman
15 Jun 2015
AM looked as if the control system was acting up. They seemed unable to control the heel properly as they powered up, and at the top of leg 1 in race 2 the main went from just below centre to well to windward during the bear away.
LONG_KEELER
21 Jul 2009
East Coast
It was nice to see them sailing again and to see how the boats are managed in heavier winds.
You feel that AM have to find a way of putting the Italians under pressure to perhaps force some errors.
