Twister_Ken
Slab. That way you can still control the sail shape.
Which is better and easier to use with less problems, in-mast or in-boom furling?
Slab reefing with all lines lead back. I can put in or take out a slab in less than a minute in any conditions and on any point of sail.
Can i put in a vote for (properly set up) single line reefing.
How do you do that when the wind is abaft the beam and you can't depower the main?
Letting off the vang and lifting the boom with topping lift takes some of the drive out and then I just drag the slab down with the pennants. Not the best thing to do to the sail I grant you, but sometimes it's better than rounding up across the waves.How do you do that when the wind is abaft the beam and you can't depower the main?
You cannot be serious!Letting off the vang and lifting the boom with topping lift takes some of the drive out and then I just drag the slab down with the pennants. Not the best thing to do to the sail I grant you, but sometimes it's better than rounding up across the waves.
I've found slab with mast cars/fully battened works better than the boom or mast roller systems I've tried.
I could easily drop and reef on an 18m mast in quite windy conditions conditions downwind, sheet in a bit (with preventer) first so it is clear of spreaders.
Maybe the new systems are better as I'm comparing to an old twister boom with the winch handle on the front of the mast!
I don't think thats fair, just because people don't agree with you doesn't mean they are inexperienced.
Of course you have "every right to chime in" with the "significant down sides", but it would help if they were detailed, thereby adding something to the debate.I personally feel in mast has its place but it is massively over hyped and over sold. I work on these gears and constantly get calls from older sailors who were told that if they spend £2.5k on an add on furler that they can reef with two fingers. There are lots of significant down sides to these systems and we have every right to chime in with alternatives.
The way the "sailtainer" in-boom works is to have a fully battened sail with a luffrope (no cars). Reef points are when the batten has just gone into the boom-slot, so the clew is held pushed out by the batten. The sail is reinforced appropriately at the batten pocket ends.
The limit of sail size is the capacity of the aluminium extrusion (boom diameter) into which it has to roll. The boom has to be at right angles to the mast (+/- a gnats nadger) or it will not roll/unroll cleanly, so a gas vang is required - but you can be topping-lift free and thus have a huge roach (as opposed to an in-mast, unless the battens are vertical)
A negative of the fixed vang, is the strain caused if the main flogs at all, while the inmast will be a loose-footed sail obviating the need for precise alignment.
If the sail jams (in the boom), or a halliard or conrol line breaks, the remainder/whole sail can be dumped and lashed to the boom as in days of yore, unlike the inmast system which may require a climber armed with a kitchen devil to clear.
Having declared my bias, I must now admit that furling requires controlled tension to be maintained on the halliard while the never-ending reefing loop is hauled (on a winch if it's any size at all). This can involve acquiring four arms if sailing single-handed!
In mast, on the other hand seems to be able to be simply handled by normal (and wrinkly) people, without a great many 'incidents'. You just get a crappy sail shape and hellish noise from the foil rattling in the mast when the sail is off for the winter. ( liveaboard grump!)
So, in-boom requires a precision set-up and provides a potentially superior sail shape, while in-mast is simpler but you may need a better genoa to make up for the mainsail size.
Finally, if you're about to invest, I would strongly recommend "try before you buy" on a boat the same as your own.
Edit: From a safety point of view, I should mention the weight of a furling boom - it will decapitate you before pushing the remains overboard, safer on larger boats where it's well up in the air.
