Tranona
Frankly I'm astonished that your main weighs in at 14kg. Mine - on a smaller boat - is heavy enough that when bagged I have difficulty lifting it over the guardrails and onto the pontoon.
Presumably there's also a furling spar (a mandrel?) running up the mast as well, which will also weigh something.
A standard furling main has no battens, no slides, no reefing gear etc - just a plain piece of sail cloth. The main on my boat feels lighter than the genoa.
This "extra" weight aloft is only relevant with an add on system on a boat that was not designed for in mast. If the boat was designed for in mast then the design would take into account the weight of the mast and sail. The section of the mast on my boat is smaller than others on similar size boats.
