NormanS
Do you furl and un-furl with the sail full or do you alter course to take the load off? just curious because I find the clutch is a bit rough on the rope when letting it slip under load which is why I take a turn round the winch and let it slip that way.
To furl, I ease the sheet, so that the sail is not drawing. I hitch the "out" line over a cleat on the mizzen, just enough to keep a little tension on it, and then open its clutch, and heave in on the "in" line, through its closed clutch. If I want to stop partly furled, I close the clutch on the "out"line, and take in any remaining slack. The tension of the line over the veed pulley at the mast stops the sail from unwinding.
What you are doing with the turn round the winch is exactly the same as I am doing with the cleat on the mizzen. You're probably doing it better.
