Mhvoiceuk
I used a piece of pipe (like the diagram) and olive oil. I couldn't get the plastic pipe to hold on the hull with Araladite(which was recommended by Clipper) and as I was running out of time -and tide - I hit upon a bodge which has worked very well. I bedded the pipe onto some marine sealant and while it was still tacky I painted a circle of resin with hardener gently round the base of the pipe and pressed some fibre glass matting into the surplus mastic and the resin. I then dabbed resin onto the matting with a paint brush. After about an hour then whole thing had set hard and it hasn't leaked at all in seven months - it's had a couple of knocks and stood firm. Probably not ideal to mix mastic and fibreglass but the end result is a working transducer.
