jfm
Re: \"In build\", sort of, pics of Sq58 - long/lots pics
The tumble drier itself had to be taken apart to get it thru the 500mm door to the utility room. As you can imagine, elec screwdriver and 100 self tappers later, it's a pile of sheet metal and plastic bits and wires on the floor, plus the drum. The drum is only about 499mm front to back, if the bearing set is removed. Then I put it back together immediately, before I forgot, and am proud to say I only had 15 self tappers left over
I just fancied a change from blue/navy covers, that's all. No good reason And yes EBY have done much above and beyond the call of duty. All very helpful, thru and thru
