Impact of tide on RPM
But surely if you apply that logic to the bow wave being created by the boat then it means that the drag on the bow wave is also the same in all directions for a given STW?
Richard
No, different forces will apply to a wave than to a boat. The point being that it's a breaking force in one direction once you follow the system all the way through. It's probably not much but it would be a difference.
My Gran once got terribly worked up because a bee flew into the car and she was upset to think that we were forcing it to fly at 60mph which was obviously much faster than was good for it...
Was it cruel not to slow down to a more manageable 20mph before it had a seizure?
What do people think about that?
A particularly energetic bee can fly at about 8m/s. If it flies into the windscreen when the car is doing 27m/s (60mph) it decelerates from 35m/s to 27m/s, which is a kinetic energy loss of 248 J/kg. If the car wasn't moving it would decelerate from 8m/s to 0m/s, which is a kinetic energy loss of 32J/kg. It therefore follows that the bee sustains almost eight times as much damage while the car is moving. Your Granny's consideration did her credit.
(I used to use this example with engineering students. Readers are invited to spot the mistake.)
The kinetic energy loss of the bee is the same in each case, from the bee's POV. Assuming the bee is already in the car.
If you are tied to a pontoon and try to get full chat on your engines in gear, you wont get it. The boat needs to be moving through the water to get flow to make the prop work. The tide WILL have some effect, given my example, I suspect that the prop will be more efficient?
Exactly. And I have done just this and for me the effect is significant.
It could be either uphill or downhill. A boat travelling down-channel, heading west against the flood, would be travelling downhill, as the water would be getting deeper in Kent, and shallower in Cornwall. If the boat did a U-turn, it would be travelling uphill, with the tidal stream.
However it would be travelling at the same speed through the water, and bow wave and rpm would be identical, travelling in either direction.
Apologies to foreigners if you don't know the channel area.
Tidal flow occurs when there is a height gradient. Constricting the flow causes a damming effect which increases the gradient and, respectively, the speed of the current, even in the Channel, which I have sailed up and down a couple of times. No matter, whenever you are traveling against a current, either tidal or in a river, you are going uphill.
Yes I can see you're right. Even travelling down a river against the incoming flood tide, the boat would be getting higher above chart datum.
But I am struggling to see why my channel example wouldn't work, with a fast enough boat. You could travel against the flood, and end up closer to chart datum. I would have to work out a passage plan to prove it.
No, strange as it may seem tidal stream does not necessarily reflect differences in tidal height, there can be an opposing current while going "downhill", or vice versa, in particular in inlets. Search for "progressive" and "standing" tidal waves :)
Yes I seem to remember the tide turns at Dover while it is still rising.
We are now falling away from springs, but tonight's HW is predicted to be higher than it was at lunchtime. (Newport IoW). How is this possible? It's not a random wind or air pressure effect, because it's in all the tide tables.
You get that effect in rivers as well. The tide starts flowing out at Kirkcudbright while it is still rising, because the river is supplying water faster than the tide is removing it. By high water there can be 3 kt past the pontoons, which sometime surprises people.
Regional anomalies or phenomena do not alter the initial premise, I think.
That's because of non-semidiurnal harmonic components influence: with purely semidiurnal components, HW (and opposingly LW) would move with decreasing/increasing heights cycle by cycle; non-semidiurnal components deform the whole curve up and down by different amounts at different times, one can then have for example a decreasing range (away from springs) given by a t+1 HW higher than HW at previous cycle t, together with a t+1 LW higher than LW at time t by an amount greater than the HW (t / t+1) difference, hence the lower range. Hopefully I have not messed up all the "t"s :)
No that's brilliant thanks. The extra 5cm allowed me back onto my mooring just now!
I think it depends on the wind, the prop speed will be higher if the hull is moving through the water. As far as the prop is concerned the water is a fixed frame of reference, but wind and sea conditions make a difference to the speed of the hull through the water.
The engine will need a higher RPM to achieve the same speed through the water if the boat is going with the tide.
Assuming no wind. Boat going 5 knots with 3 knots tide is pushing through the air at 8 knots. Same boat going against the tide is only pushing through the air at 2 knots. Less air drag = less power required.
The RPM counter is electronically controlled. Once the engine has charged the batteries the electricity passing through the system might ( does it?) change. Has one considered that the RPM counter could be altering due to fluctuations in charging of the batteries & it has nothing whatsoever to do with what has been discussed. IE has the RPM meter been calibrated at all states? . If the data ain't right then you are wasting your time. How often were the readings taken? Once, twice dozen times?
The OP states later in the thread that he "Always sees a small drop in RPM" But conditions will not always be the same. Wave motion will be different, Wind will be different. Tidal flow & depth will vary..So unless the data ie the revs drop, is taken over the same conditions it is impossible to isolate a single cause. I cannot accept that a single reading in a certain condition can prove a particular cause. One has to take several readings & i doubt that the OP has motored up & down the same stretch of water a dozen times in succesion for that purpose ( Sad if he has) What was the effect on speed through the water?
We can all talk about( say) bow wave , but that changes if the conditions change. Likewise if the wave motion changes, then that cannot be isolated as the cause because it is mixed with other factors. Therefore, none of the theories suggested can be rejected outright & none can be even accepted if the means of recording the data ie the instrument- is wrong to start with
Only tank testing will solve the issue.
Exactly so. And there, boys and girls, is the most likely answer to the OP’s original observations.
Athomson I do like your explanation. I wondered from the outset whether we are all to fixed on the boat moving through a homogeneous media (the water) when it is more complex because there are two very different media involved and perhaps the water is less homogeneous that we give credit.
I also agree my observations are wholly inadequate (scientifically). However they are a little uncanny in their consistency. I must motor upper and down the same stretch sometime!
If an engine is at full throttle & his throttle lever is hard over & revs at 3500 rpm under load I would assume that the revs are being kept there by the govenor ( or whatever a diesel engine has to stop over revving) So if the load is lighter why does it still not rev at 3500 & stay at that all the time. Has the OP got an engine problem coming. does he need a service?
