Birdseye
on a boat that you could club race and weekend cruise - plus it must be able to dry out. What would you chose?
I think the resounding silence may be due to the drying requirement? I sail and race on the Firth of Forth and the only 2 boats that race and can dry are my Parker 275 and another identical one. And drying is ocassional and not regular.
I don't think my boat would do well on a drying mooring. I got it more for shallow draft and sometimes staying overnight at a drying harbour.
So is the drying requirement for a half tide mooring? I am not sure about a lift keeler for this due to mud up the keel box? But maybe I am wrong. In which case a parker may suit. Bit tender but sail well. No parker 275s for sale?! How about a 31? http://www.parkerseal.org.uk/forsale/boats.aspx
How about a Sadler 290? Bilge keel but quite quick? Too expensive?! None for sale?!
Then I think maybe the fastest older bilge keel is a Fulmar.
I looked at the py ratings on byron software. I think the problem with racing is that its no fun coming in half an hour behind every one else and winning on handicap?
I should have asked at the beginning what racing you are planning on doing and what other boats are in the fleet?
Parker 31? Dries on it's big sturdy lifting wing keel, goes like the clappers. You might just get one for 30k although they're a bit rare.
You can always buy some legs if you do want to dry out in the likes of Ilfracombe.
You don't really want a lift-keeler in the Bristol Channel, if you actually want to cruise as well as race. Too many chances of hull damage to the bilge from uneven bottoms with occasional stony bits. Iron bilge keels (not encapsulated) are what you need, which really ties it down to Sadlers or British Hunters. Without being patronising, Bristol Channel racing is fairly low-level compared to Cowes/Hamble. It is though very skilled in terms of use of tides, eddies, etc.The drying requirement is for the Bristol channel where there is either more than enough water or none, depending on tide. Mostly soft mud bottoms but as an ex industrial area, a lot of rubbish on the sea bed so nervous about drop keelers. Most of the boats used / raced here are bilge.
Exactly: how many of these 'cruising lift-keelers' go into the really interesting places, Lynmouth, Porlock, Clovelly, and on the Welsh coast Solva etc. etc.There are a LOT of cruising lift keelers in the Bristol Channel, although I think this is a consequence of the lack of modern bilge keel choices .... snipped ..... And all the shiny new lift keel boats I know spend all of their time in marinas anyway.
Cheers
