udo
How depressing to read such a narrow and "purist" viewpoint on owning a wooden boat - as if nothing has been learned and no new materials and techniques have any value. Boatyards are full of decaying boats (or used to be) for two reasons.
Hi Tranona,
First of all, I have not given up on wooden boats at all and I am still very interested in using modern maintenance solutions like Polyurethane varnish (Coelan) on wooden boats.
I set aside any kind of emotional judgements and try to understand the opinions of some of the experts here on this forum.
The MAIN issue is here the marriage between 2 type's of hulls: Solid Mahogany planks on oak rib's, carvel build and on top of that the Plastic / epoxy sheeting which is having far less flexibility.
Described here is, by some experts, that it could work, but only done in a proper way and if not done in a proper way, it could lead to major disasters and the problem is to find out if a boat is having the potential to end up in a disaster.
The situation here is: The Plastic hull is leaking and that's already a bad sign.
Above the waterline problems as well.
Therefore we must inspect the boat out of the water and this will lead to me spending in total between SEK 4000 and SEK 5000 (SEK 10 - EURO 1 roughly) not knowing that I will get the boat!
It's not important that the purchase price of this boat is an absolute bargain.
What is more important is to get an idea of future maintenance and this boat is having the potential of becoming a money pit, which will not be the case for any wooden boat. This boat is simple higher on the scale of anticipated risk.
I have to work with a limited budget, therefore I can't afford the risk of this boat.
Someone else who could afford taking the risk spending lot's of time and money, could maybe take it on. Very likely (according the my surveyor) that the whole hull needs to be plined (above the waterline) and that is already a very big job, which is more than regular maintenance.
That's all,
Best regards,
Udo
