James_Calvert
I've done the give it a suck technique . At the tap. Turn it on first.
That will not work with a typical yacht system that has a positive displacement pump. The valves are effectively NRVs, so water (or air) from downstream cannot pass the pump.I would try connecting water hand pump outlet to the tap and try to push some water down to the pressure pump.
That is a common way to remove hot water airlocks in domestic systems (connecting cold tap outlet to hot tap outlet).
Either suck on a tap or use a vacuum cleaner. That will draw the water through. Standard plumbing practice!
