Boater Sam
Many were fitted with PRM 160 boxes too. And of course there was the Delta.
On that box, and mine, (500n I think from memory) you only got 'ahead' so if ahead was astern due to a wrong handed prop.....He put the bolt into the wrong clutch then?
I didn't know that of the PRM 150. The larger boxes, 160, 240, 280 etc you can lock either clutchOn that box, and mine, (500n I think from memory) you only got 'ahead' so if ahead was astern due to a wrong handed prop.....
Edit: in the handbook online rotation is selectable, but not the 150
PRM150
1) Remove the 9 hexagonal bolts securing the rear manifold to the gearcase and taking care not to lose the small socket wrench located inside it, take off the manifold complete with oil pump.2) Rotate the input shaft until two socket screws in the clutch align with the two holes in the rear of the gearcase.
3) Insert the socket wrench through the two holes and tighten each screw in turn; this locks up the clutch plates, providing drive for a right-hand rotating propeller. (Note: left-hand rotation cannot be provided).4) Refit the rear manifold and tighten the bolts to a torque of 30Nm.5) Ensure that sufficient oil remains in the gearbox to avoid further damage.
Going round the boatshow last week - discussing an engine replacement - one of the items that kept coming up was a hydraulic gearbox.
These seem to be larger and more expensive than mechanical boxes, but have the advantage of being able to deliver full power in both directions.
Do hydraulic gearboxes have any other benefits or disadvantages? Are they quieter, smoother or help with shaft alignment?
With a PRM if the oil gets low it takes a second or two to engage. If it gets really low, of course, there will be metal to metal problems, as the input shaft from the engine is still rotating
I think you are confusing a hydraulic drive (which allows remote engine location) with a hydraulic gearbox (where the gear trains in the box are selected hydraulicly, such as a PRM150 and some VP gearboxes), and one last minor advantage that some boat designers like, is that a hydualic box can be installed in a different location to the engine.
