homerj
I`m repairing a separated hull / deck joint ( biscuit tin lid type ). The plan is to replace all corroded galvinised steel bolts with stainless ones at closer centres and use some sort or sealant or adhesive between the joint. Could anyone recommend a suitable material for this purpose? I intend to secure the deck mounted chain plates to the hull sides with bolts and brackets on the inside to prevent further problems. Any help much appreciated.
