Bobc
Like it or loath it, you cannot deny that it's a work of engineering excellence.
Some people say that F1 cars are ugly, but they're bloody quick.
They use them as hydrogenerators for power, having two gives redundancy. Presumably given their 0 fossil fuels aim it has electric drive and no conventional generator.
I'd love to see the interior/cockpit and foils but I imagine they are keeping them thoroughly under wraps. Interesting that this time they can move the foils in two axes, sounds like a lot more work for the skippers (and designers).
Could have sworn I saw them, must be going mad...Where exactly are these two propellors / generators? I only see one for the engine (folded) at 1:00. I don't see any hydro generators.
That's true and it has to be remembered that us cruiser types get the benefits from racing further down the line. Eventually that is.
I wonder though if the gap has never been wider and it is difficult to see where the benefits are going to come from and how affordable they might be. Particularly foils which to some are not cruising or racing. Americas Cup interest is probably now at it's lowest ebb .
Personally, I love watching the wind and kite surfers .
Look at the old photos of the J Class boats. I think the gap between a typical boater and the J Boats was pretty wide then.
I think it looks fantastic.
Question though, it may be very obvious from the video(i cant stream videos where i am currently located) but where are the foils? Are they fully retracted on this boat or just not installed yet?
I suppose that a companion hatch will be fitted. The boat looks to be set up to scoop the bow wave into the cabin.
I read that due to the new design, The foils haven't been fitted yet, so as not to give it away to the other competitors yet! I can't wait to see how it performs on the water.
A watertight lockable door I suspect.
The cockpit will be self-draining, I assume through that big hole in the middle at the back.
The "hole in... the back" is an escape hatch for getting out when inverted, via a crawl space under the aft deck. It's a feature of lots of offshore designs, including all the IMOCAs, Mini 6.50s etc.
Presumably the cockpit area under the pink coachroof will have lots of bits of string in it so would be quite hard to seal, I would guess there is a proper watertight door forward of that.
Did I spy a tiller at 0:39 in Minn's video?
