peter2407
On a rib in a sea, where the primary fuel tanks are under your seat and the spare fuel is elsewhere? If i could install an instant replenishment system, ie as fuel is used it is replaced all the better. TIA.
I don't know if this is still the case but at the Southampton boat show there was a man selling a hose with a bell shaped fitting and a marble inside at one end of the hose. You jig the fitting in the diesel container and it's no spill no return filling whatever the weather. We used a funnel that removed water. While filling you can you can look in the container to see if there is any dirt at the bottom - which was endemic in the Caribbean. We used another one to transfer water from containers. They were the best pieces of kit on the boat after the wind vane.
+1 for second tank.The idea of pouring fuel from one tank to another isn't going to work on a rib bouncing around at sea. If the second tank is a proper fuel tank fit either a second fuel line to the engine or a change over lever to switch between tanks.
That is the sensible way to do it, but I think you will find the fuel is drawn from (near) the bottom of the tank so contamination is a risk. A filter in the fuel line is still a good idea.+1 for second tank.
I, for my sins have occasion to sometimes operate a boat which is used for general purposes to do with Keelboat sail training. We always carry a full spare tank, and when the tank in use has gone down to about 1/4-full we pop off the petrol pipe and clip it on to the full tank. This ensures that, for one thing, any possible contamination at the bottom of the tank is not sucked up, and in the event that a refill has been forgotten about, (almost never happens) there is at least a 1/4-tank of spare petrol in reserve. The proprietary clips on the tanks are proof against the entry of any contamination, or air, to the fuel feed and eliminate the possibility of any spillage on the deck, which could become dangerously slippery if 2-stroke mixture is involved.
i have one, bought from a forumite, its very good & clean to use>That's a jiggle siphon, which can be had for cheap at Toolstation: http://www.toolstation.com/shop/p46767
Thanks for potsing that URL, I would strongly recommend it as the easiest, cheapest and best way to transfer diesel and water, even if the boat is pitching and rolling as we found out over the Atlantic.
