How to Paint rusty piles
Pasarell
18 Jan 2007
Greece
Biggest issue for you is the external surface between high and low water marks (splash zone) where corrosion will be greatest. When new the piles were probably coated with a decent glass flake epoxy but in the splash that is unlikely to last more than 6 or 7 years, less if there is any abrasion.
You cannot effectively repaint so normal solution is to put a petrolatum gel incorporating an anticorrosive around this area and secure in place with a protective sleeve of polyurethane or HDPE. This should exclude air and water from the surface and the anticorrosive additive will slow existing corrosion almost to a stop.
The anticorrosive is normally supplied impregnated into a felt strip to wrap around the pile or as a layer of felt bonded to the inside of the jacket.
Piles should have been made with a corrosion allowance for their specified lifetime but those allowances are being affected by air and seawater warming causing corrosion to accelerate.
Corrosion inside the pile should be minimal
