AntarcticPilot
I have a manual "Anchorman" Winch, which is basically the same winch without a motor! But it works very well; if I motor slowly (tick-over speed) towards the anchor it works well. But the trick is a) to use a long winch handle (I use a "One-Touch" handle) and b) to get your weight directly over the winch. The latter makes a surprising amount of difference.I had the same windlass on my last boat and the motor seized so impossible to move it at all. As suggested locking it and using the handle works very slowly if the motor is free. I retrieved the anchor manually.
Obviously, I don't know how the motor-driven winch is arranged, but surely the clutch mechanism will completely disengage the gypsy from the motor, allowing it to be used exactly like my manual winch? I know one problem with the manual winch is that if not used for a while, it can be difficult to get the clutch to disengage.
