How to cut a Larger Hole where there is already a smaller Hole!
Habebty
Norfolk/Suffolk
I am fitting new instruments. I need to cut/drill a 92mm hole where there is already a 60mm hole in the GRP hatch garage. Bit tricky to centre a conventional hole cutter with drill bit, is a jigsaw my only option?
Daydream believer
6 Oct 2012
Southminster, essex
Drill a hole with a hole cutter of the new size in a bit of 6mm ply. Clamp this over the position where you want it. You could screw it in place if you can find a position for 2 screw holes Then stick the new hole cutter in the ply hole & it acts as a guide..
Alternatively, You could screw a piece of wood or ply across the hole on the inside, screwing it through an area that is going to be cut away. Then using the drill bit of the new hole cutter start drilling the new hole. Through that bit of wood & the area you want the instrument.
As you get deep enough into the instrument wood the hole saw will sit in the groove it has cut so you can carry on & eventually the guide piece & the instrument piece will fall away complete with the 2 screws that are holding the starter piece of wood.
johnphilip
15 Nov 2005
Really easy, I was given the tip when I had the same job. Put the 92mm cutter on the arbor and a 60 mm cutter screwed inside it. There is just enough thread on the arbor to take the inner cutter and the 60 mm one will protrude just enough to engage the smaller hole and pilot the bigger cutter.
Refueler
13 Sep 2008
Far away from hooray henrys
OK - two ways :
If you can get back of the existing hole ... glue a thin piece of ply or material to cover the existing hole. But size is less than the new. Mark centre and then use the Hole Cutter ... the centre drill uses the ply as its centre.
If you cannot glue piece behind - then first you need to draw the new circumference onto the console with old hole centred. Now take piece of ply or material and glue over the hole ... making sure you can still see the marked new ... set your drill to centre so your hole cutter cuts the marked hole.
seeSimon
30 Jan 2024
I'm facing at least two similar hole enlargement conundrums this winter...beginning to wonder just how much boat will be left after say another two instrument generational size increases and upgrades?
A common problem it seems?
...also currently trying to find a moderately sized/smaller estate car (golf/focus/astra or similar) for narrow lanes and difficult parking spaces here in SW UK.
However, Plenty of pointless 2WD fat SUVs, Passats or Audi A4s estates to be had!
Boathook
5 Oct 2001
Surrey & boat in Dorset.
I tried that and it didn't work for the sizes I was using.
Ammonite
7 Feb 2007
If #6 doesn't work for you or you want the larger hole slightly off centre.
Screw a scrap strip of plywood over the existing hole with the screws 5mm outside of the edge. This will centre the larger holesaw. Use the holesaw in reverse when it first touches the gelcoat so it doesn't chip /grab.
fredrussell
24 Mar 2015
This^^^. Job done.
