pmagowan
The problem is that to remove the crud you will have to give the walls of the tank a really good blast. Otherwise you will end up doing as above and simply making a couple of scrapes through it. Imagine trying to clean a filthy saucepan with a small tube through a hole? It really needs a scrub. I wonder if something could be done with a high pressure hose to blast the crud off the interior. You would need to undo all the pipes to allow the pressure out. You would either have to use diesel as the medium (I don't know if pressure washers can handle this) or you could use water and then use something to absorb the water residue once pumped out(I think acetone works). I don't think simply pumping it all out will really get the crud out as it will simply go to the bottom. This is why the hatch is the only practical option as you can get a hand in and literally scrub the tank. I completely replaced my old mild steel tank as it had crud, rust and no hatch. I now have a plastic job with hatch. No probs since.
