Tim D
cutting a hole in it is the easy part, if its a square or rectangular hole you would mark its position then drill out the corners first with say a 10mm or 12 mm drill then disc cut the rest with a plasma disc, gas cutting wouldnt work as its a stainless tank so wont work as it wont oxidise, the harder part is rendering the tank safe so as to not explode it by igniting any fuel vapours which are left inside it with the sparks from the cutting disc, this can be done quite easily by forcing a diesel engine exhaust through the tank for a while, not so easy though on an installed fuel tank on a boat, easy if the tank is removable.
