Lakesailor
The LMA ones I linked to are a very good half-way-house solution. They don't have the solid body of the Jubillee clipHave you considered using this type of clamp instead
The only disadvantage I see with this type is they are dearer, you need to disconnect the hose from the fitting to put it on, they are a bit wider than a worm drive clamp and you need to know the exact outside diameter of the hose as each size clamp will only cover about 3 to 4 mm in hose size
Regards Don
