I think hammerite is a bit pointless, but my first thought also was hit it with a hammer, if it’s ok after that then it’s ok. Maybe an anode is a better idea than painting which is only going to put paint flakes into the seaGet the scraper ... wire brush .... emery cloth and clean it up .... good coat of Hammerite and have it another 15yrs !!
Once you clean it up - you can hit it with a hammer to check its still good to use.
Some will advise to clean up and re-galvanise ..... me ? Hammerite !!
This might help youIs this Spade, around 10-15 years old, too rusty?
View attachment 172345View attachment 172346
Should I replace it, treat it (how?) or just carry on?
It was in fairly frequent use up to last October. Last season saw about 50 nights and several shorter stops at anchor so it has been fairly busy.Just as an aside. It looks as though the anchor has not been used recently - or the rust on the toe would have been abraded off allowing sight of bare metal (and surely it was not on the bow roller of a member's yacht ).
J
The rode is in fine condition, after about 8 years service. The anchor still feels solid and getting apparently heavier to lift. I'll try a hammer on it (checking for loose scale?). The shank/blade joint is solid. I doubt if I could get it apart.
