Nostrodamus
If you keep your boat in the water over winter how much winterizing do you do and what are the most important things to do?
Where you are, nothing special except allow ventilation if you are leaving the boat for any length of time. If you have shore power then keep the batteries topped up and perhaps a low powered tubular heater to help air circulate. Run the engine regularly under load for minimum 30 minutes so it gets to operating temperature. If you do have problems with condensation then a dehumidifier is useful. If you are living on it, just behave normally. If you are comfortable then the boat will be.If you keep your boat in the water over winter how much winterizing do you do and what are the most important things to do?
Really no need to do anything. Had my 1GM for nearly 20 years, mostly in water all year round. In our environment seawater is highly unlikely to freeze.This is my first year with an inboard (1GM10). How do I get anti-freeze into the raw water system while afloat?
Close the raw water sea cock remove the pipe and immerse it in a bucket of 50% antifreeze and start the engine get someone to watch the exhaust and stop the engine when the water coming out turns the color of the antifreeze job done.
Mike
How about taking the boat out for one last blast under motor, returning to the mooring and then running anti freeze through it? It's bit of a faff, though.
Or is there a way of draining all the seawater out of a raw cooled engine? Surely that would protect it.
I am also interested in this topic. My boat spent the last two winters in the water in a marina on the Hamble. I left electrical heaters running with the thermostats set at the lowest setting. I did nothing else, since I sail all winter, at least once a month. Had no problems.
This year I am on a mid-river pontoon in the Hamble with no shore power. I understand that being in the water keeps the boat warmer than the ambient air temperature, but with no heat at all -- are there risks? I am wondering whether I need to drain down the fresh water system and/or run antifreeze through the engine raw water circuit. PITA to do once or twice a month, after every little sailing weekend.
