Zagato
Just interested, does it work from the gearbox, seems pretty accurate...
So it doesn't count the (last) 10 minutes that you ran with no oil pressure?The engine hours meter itself is just a counter. A variety of wiring methods are used. Mine takes its ground from a changeover contact on an oil pressure switch on the main engine and the positive supply from the instrumentation supply. Engine on and oil pressure positive and it quietly counts time. Ignition on but no oil pressure and the clock stops.
They are basically a stopwatch with a control circuit.
nope that's recorded in the volume and number of the knocks from the big ends.
Because then it wouldn't be an hour meter, it would be accumulated revs. But I take the point.I'm surprised engine rpm isn't factored in to how quickly the hour meter spins...
I'm surprised engine rpm isn't factored in to how quickly the hour meter spins. You could have two identical boats, one owner flush with cash cruises at WOT 3500rpm, the other can only afford max 2000rpm. One set of engines have done a lot more work than the other?
Anders
Well, an engine hours counter does what it says on the tin - counts the hours an engine has run since the counter was installed.
I think you're trying to design a gauge which would put a numerical value on "how worn is the oil?" - or maybe the engine?. This would need to account for more than just revs, since things like time spent idling, in/out of gear and so on all have an effect. (Without complete agreement on any of these factors - see several threads on this forum.) Even if it was possible to gain agreement on weighting factors (maybe different for different engines) I struggle to see why anyone would want one. It might be possible to get a more accurate measure of when to change the oil, but if this was over the manufacturer's (deliberately conservative) hours figure are you going to risk it?
