EastCoastChris
Hi All,
I'm really hoping someone knows the answer to this one!
The chap who did some repairs on my hull appears to have done the following....
Routed out the area that needed replacing with a chamfered edge (hard to see in the photo). I presume he used a template as you can see the pieces of tape with registration marks on them for lining the template up.
He's then routed a replacement piece from new ply to exactly fit into the area he had previously cut out. The piece fitting in has an exact reciprocal chamfer.
You can see from the image below he's got a very tight exact fit.
I'd really like to know the easiest method for doing this, does anyone know how it's done? The only method I could think of requires a chamfer bit with a guide bearing at the top and these don't seem to exist.
Chris
P.S. I've not found any more problems with my hull, I'm wanting to use the technique for dropping a piece into my foredeck.
Chris
