EastCoastChris
This is a collar that fits over the guide bush mounted on a router. It is removable, allowing you to compensate for the diameter of the cutter (ie not producing a patch smaller by the cutter diameter)
Thanks, that looks perfect, except the largest diameter cutter they allow for is 10mm
I'm now wondering if I do Step 2 in my master plan using a second 45 degree cutter with a bottom bearing whether that will work.
Feel like I'm very very close to a solution!!
Chris
