NormanS
Stanchion bases every time, which is actually very seldom, as we are seldom alongside. Putting a load on the wire or the top of the stanchion is inviting too much leverage on the base.
On a yacht, toe rails. On a cat stanchion bases, because cats don't have toe rails, with a big one forward and another big one aft and smaller , or less big in-between.
Jonathan
Yours may not be intended to catch a person. Ours are. That's the way the boat was designed. The stanchions are taller than standard. They are far more substantial than many that you see with 3 screws tapped I to the deck. The stanchions bolt to the toerail. The toerail is bolted to the boat every 100mm with M8 bolts. The stanchions are spaced closely to provide additional strength.[*]Lifelines are not intended to catch a standing person. They are intended to catch a person that is sliding or one that has enough sense to sit, scoot, or crawl. Hand holds and jacklines (jackstays) should be well inboard.
[*]The stanchions are to hold the line in vertical spacing. They were never intended to hold the full load of a falling person. This is why strong bracing at the ends is VITAL.
For us, going forward to deal with an issue in bad weather, requires something more than a flimsy wire with low stanchions spread widely apart. It is the obvious hand hold on the high side of the boat but it also needs to catch you should you be flung to the low side. As additional safety on ocean passages, we lace in a zigzag the bottom guardwires with string that threads through the holes in the toerail. This keep somebody from rolling under the bottom wire.
I can't imagine having guardwires that you fall against and go straight through because the stanchions are not substantial enough.
So why don't modern production boats make guardwires fit for purpose? It's not that hard.Standard production boats are not as strong as yours ... they are as another stated - to work in conjunction with rest of boat ...
Stainless steel guardrails on my boat and cleats.
Yachts tend not to have rails and for some reason are often short on cleats. It's like the designers have not considered the boat might be moored up to a pontoon or wall.
Since a strong guardwires are a primary safety aid, I do find it odd that on some boats they are so flimsy. Almost decorative.Why don't they make light bulbs to last a lifetime ? Despite the claims of modern ones !!
OK ... Guard wires are a little more serious than a ight bulb ... but we could ask why boat builders don't put Lifejackets .. Lifebuoys etc on boats as part of the 'factory inventory' .... (please don't quote Sailaway sales - they are at best a mediocre attempt).
On flat roofs on commercial buildings, safety railings around an accessible roof need to be strong enough to stop somebody falling over the edge. It's not much different on a boat, with similar consequences. If a worker fell through the guardrail system the HSE would be all over it and somebody would be sued. Why not with boats guardrail systems?
On my boat it's because tying them to the lower wire leaves the fender line in contact with the teak toe rail which would both abrade the line and the toe rail as the boat rolled the fenders back and forth and up and down against the pontoon. It might be hard to visualise the geometery, but the toe rail is wide enough that the width of the fender makes the line more vertical and keeps it clear of the toerail when the other end is higher up. but it's in contact with the toe rail when tied further down.For the majority who do tie fenders to the guard wires, why the upper one and not the lower one?
