How do I remove sikaflex from gelcoat?
haydude
7 Apr 2009
Question in the title ... some nutter glued my cockpit speakers with sikaflex and now they need replacement ...
Elemental
30 May 2007
Weymouth
There is a product - Sikaflex 208 Remover - which may help. It's not quite as eye-wateringly expensive as the sealant products.
But that only works for un-cured Sikaflex. Sikaflex website states that it (cured) can only be mechanically removed. I used a sharp chisel which got rid of most of bits I had (292) after fitting a new transom fender.
Scotty_Tradewind
31 Oct 2005
Me: South Oxfordshire. Boat, Galicia NW Spain
This is one good reason that I don't use a sealant that is going to go off rock hard on anything other than semi permanent things like skin fittings etc.
When I resealed stanchions a couple of years back some kind person had at one time used a 'hard' sealant. It took ages to clean up surfaces again, so I used a builders mastik (which can be cleaned up with white spirit) to reseal them and they have been watertight for a couple of seasons and well washed over by the green stuff in between.
Seajet
23 Sep 2010
West Sussex / Hants
Here's a tried & tested solution...
images
oldsaltoz
4 Jul 2001
Australia, East coast.
I have always used a wooden chisel, cut from scrap timber about 30 degrees, the timber is hard enough to abrade the sealant but soft enough to not damage the gel coat.
Finish with Acetone on cheese cloth.
Good luck.
