How do i mesure up for a second hand sail
Chris.mcc240
22 Feb 2011
Furling genoa..
My westerly centaur has a Rotostay 1V 'model 415' furling system on which the genoa was furled. This has worked fine however i have now completely destroyed the sail, so im after a new sail, however i want to get a second hand one cos new is just to expensive. Sail loft i spoke to in ramsgate said roughly £1K so i don't have the luxury or a professional measuring up for me.
I've mesured the old sail as follows
Bead 7mm
Luff 30:2
Foot 14:4
Leach 29:3
However i have no idea if this sail was the original mesured up when the system was fitted, i suspect it was! It worked without fault.
The two things im worried about what size luff tape do i need, the grove is 4mm and the internal dimension of the channel is 10 mm
Would i get away with say 6 to 8 mm ?
The length of the luff i measured the sail on my garage floor so it was not taught, i thought getting a line hoisted up as far as it will go might be worth a try?
I can probly get away with a few inches short, but to short and it causes the halyard to wrap around the top of the extrusions , jamming it unfurled! So do i need to worry about stretch in the luff . I know the simple answer would be to go to a professional but for the cost of a new one i can get 3 or 4 seconds!
Any ideas where to start and how to mesure up appreciated ....
merlin3688
6 Oct 2011
Brightlingsea, Essex
www.sailingschoolandrigging.com
Google XWRigging who make Rotostays, they will be able to tell you the bolt rope size, I know they are larger then most, most modern furling gears use a 5mm finished luff tape.
XW Rigging. 17 Haslar Marina, GOSPORT, PO12 1NU. Proprietor : Paul Cochrane. 02392 513 553. 07805 849 419.
Chris.mcc240
22 Feb 2011
I think you have to be a member to post a question on the WOA site, though i could be wrong.
Thanks Cindy please let me know.
I would still like to mesure up though as my question so i can understand what i need..
VicS
13 Jul 2002
You are wrong. The WOA forum is open to anyone. You have to register as a user of course but you do not have to be a member of the WOA
http://www.westerly-owners.co.uk/woaforum/
BUT by not being a member of the WOA you are missing out on the benefits of membership. http://www.westerly-owners.co.uk/ab_join.php
There is also an active Yahoo discussion group see http://www.westerly-owners.co.uk/ab_discuss.php
wilkinsonsails
4 Jan 2010
Kent
With the Rotastay 1v,the max luff available for a centaur is 31'6,the best bolt rope size is between 7 and 9mm..Quite often the bolt rope is stretchy plastic cord so you can often over tension it and get it to long.:eek:.
Depending on where your halyard diverted is fitted the luff length can get shorter too.
Pm if you would like the sail measurements for Centaurs.
Cindy
