Concerto
Not a plastic dustbin!Sounds like you have an opportunity to put out a small controlled fire, perhaps in a dustbin, and do some training.
I agree. Hold a fire drill for all your crew. It’s surprising how many people have never operated a fire extinguisher, so it’s a good opportunity and a way for them to experience it so it’s not a shock the first time they pull the pin in an emergencySounds like you have an opportunity to put out a small controlled fire, perhaps in a dustbin, and do some training.
+1Ask your local fire brigade?
If there's a fire fighting training centre anywhere near you they will have them off you for demos.Sounds like you have an opportunity to put out a small controlled fire, perhaps in a dustbin, and do some training.
No. Most small dry powder extinguishers are built on the same principle as an aerosol can: they don’t have a separate gas cartridge, rather the whole can is pressurised. To disassemble them, you need to get rid of the pressure before you can safely remove the trigger assembly. So Graham’s idea is a good way to minimise mess: invert the extinguisher and trigger it. You’ll get a burst of powder then just escaping gas. I’d then simply take the extinguisher to the dump as it will be discharged from the pressure point of view, which is what the council employees are worried about. The powder is messy but non toxic.
Having spend many days doing official fire warden training I strongly recommend that everybody sets off an extinguisher. Far more useful that giving it to somebody else to use, hence the suggestion.If there's a fire fighting training centre anywhere near you they will have them off you for demos.
