Ubergeekian
Quite so. My ultimate aim is to do the ARC when I retire - or maybe sooner.
Serious question: why the ARC? Why not just do it under your own steam. Wouldn't that bring a greater sense of achievement?
I reckon most don't do the ARC to help them cross the atlantic. They do it for the parties and the whole community spirit of the thing. The fact you have to sail across an ocean to get to the after party is just a bonus.Serious question: why the ARC? Why not just do it under your own steam. Wouldn't that bring a greater sense of achievement?
y.
Another thing that maybe useful, is a notebook to note what went well and what went badly after each sail. It is rare to have a perfect sail so the what went badly would rapidly fill up! This is a technique being introduced into UK surgical practic
TS
Whilst a big boat such as that wouldn't appeal to me, I find a lot of the "advice" given is a bit demeaning.
Most comments border on the "well you've bought a big boat, but you really need to learn how to sail"
Fair enough, bit the OP did say
No-one seems to have followed up on that.
Still, not unusual for the forums.
>Ocean sailing skills are something of a misnomer. If you can sail along coasts, then oceans are easy. It just takes longer thats all.
I agree coastal sailing is somewhat strenuous simply because of the navigation. I wouldn't say oceans are easy though. Firstly there is nowhwere to run and hide if a gale/storm is forecast. Secondly you can be sure that you will have a series of breakages. Typically torn sails (incredibly some don't carry spare sails), engine failure, generator failure, water maker failure, water pump failure, broken boom vang, broken goose neck, damaged rudder, leaking keel bolts, broken pole fitting, broken pole fitting on mast, stranded or broken rigging, block failure, block torn from deck, winch failure, instrument failures, nav light failures etc. The reason these things happen everything is loaded and moving 24x7 for weeks.
We have had many of those and know cruisers who have had all of those between them.
Never underestimate ocean sailing. People talk about the milk run, it can be but usually it isn't.
Tudorsailor,
in the same vein as previous posts, I'd suggest a dinghy / dayboat ( mind it's easy to get ripped off with dayboats ) personally I think things like Shrimpers silly money for what they are, not too brilliant offshore and a diesel still allows bad habits.
I'm biased, but I've never found anything to beat one of these;
www.anderson22class.co.uk
- responsive enough to teach you a lot about sailing, while seaworthy to keep you out of trouble;PBO and S' Today seemed to rather like her.
Forget where you are but you're welcome for a spin from Chichester ( and my boat is NOT for sale, no ulterior motive ) !
Exactly.
Another reason why I don't really go with the 'go racing' advice.
Racing puts so much more strain on the rigging and sails.
When ocean cruising the first priority should be to arrive in one piece, not to arrive first/fast.
How do you learn to sail better? The only answer to that is to race. Unless you compete with others you never know whether you are sailing well or not. I'll give a frinstance. We have 2 Sigma 33 in out racing fleet, one owned by a long time racer, the other but a good average cruising sailor. The latter is a consistent 15% slower in each and every race and its all down to know how. So race as crew with others and race your own boat.
That's a good way of learning to sail faster, not necessarily better.
Ability to stop the boat in a defined place an manouver it with confidence in confined quaters under sail is another. Ability to make the correct sail choice for the conditions is another. Ability to manage a crew another.
Define "Better" then?
I'd say that ability to make the boat go faster, esp in very light or upwind in very strong conditions was one measure. Ability to handle manouvers in a prompt and seamanlike way is another, ability to get a boat from A to B with no damage was another. Ability to stop the boat in a defined place an manouver it with confidence in confined quaters under sail is another. Ability to make the correct sail choice for the conditions is another. Ability to manage a crew another.
All things that are immesurably improved by racing, perhaps you'd care to name a measure of "better" that is not improved by racing?
There is much about successful cruising which has nothing to do with boat handling or going faster![]()
So I would very much echo the advice that to really know how good a sailor you are, go racing. I thought I was pretty competent before I started racing, turns out I was average at best. The improvement in my boat handling skills in particular is outstanding. When you can hold a yacht on the startline in company with a whole bunch of others, and pick through the pack at a crowded mark rounding, picking up a mooring under sail no longer seems like a daunting task in the slightest.
