D
Deleted User YDKXO
Arrived on boat in Italy 2 days ago to find service batteries completely flat. No problem I thought; it is 6 weeks since we used boat and I never leave shorepower connected whilst we are not on the boat so batteries must have been flattened by various technicians who have worked on boat in our absence. So I switched on the shorepower and went to bed. In the morning I was somewhat perturbed to see that the battery voltage as shown on the voltmeter was only around 23.5-23.7V (they are 24V batteries and normally show 25.5-26.5V under charge) and also to my surprise, I saw that the battery charger was only drawing about 20A. Normally it draws 40-60A if the batteries need charging. Also I noticed a bit of a 'bad egg' acid type odour in the boat which I didn't immediately connect with the batteries as my first thought with any smell on a boat is holding tank.
Anyway I called my local Mr Fixit who consulted an electrician who pronounced that the battery charger may be reducing it's charge to the batteries because it's temperature sensor was detecting a higher than normal temperature adjacent to the batteries. Sure enough when we disconnected the temperature sensor, the battery charger whacked straight up to 60-70A. However we also noticed that the batteries were a bit warm and it was also obvious that the bad eggs odour was coming from the batteries so we concluded that the temperature sensor was telling the truth and that the battery charger was correctly not giving the batteries full charge. We also turned the engines on and checked the output of the alternator feeding the service batteries and this was showing about 70A. So based on this evidence, I decided to change the batteries. The batteries are all sealed Energiser Commercial Premium units.
I'm currently waiting to hear whether we can get replacement batteries and then of course there will be a further delay whilst they are fitted. The problem is that we are here to move our boat to Sardinia and we should have left yesterday. So I've got 3 questions that I'm hoping the forum can answer
1) If we cannot get replacement batteries quickly, is it wise to go to sea with the engine alternators pumping 70A into batteries which are obviously knackered and overheating? What is the worst that can happen?
2) What is the odour? If the batteries are giving off hydrogen, which as I understand it is odourless, what am I smelling?
3) It is only 4 months since I bought the boat and the surveyor carried out a test on the batteries before I bought it and pronounced them to be in good order. We have used the boat 3 times since and there has been no indication that the batteries were failing. How can batteries fail so suddenly?
