jusw
I have a "Houdini" brand escape hatch fitted to Treble C - I think they are pretty universally used across many boats.
I have a leak - whenever we plough through a wave I get an eggcup full of seawater on the upholstery - not very welcome.
I'm unsure if it's the gasket around the opening panel that needs replacing or whether the leak is between the glass and the aluminium frame.
You often walk on the glass and some of the hard "packing" around the glass has come away from the frame.
Have any of you had a similar issue? If so, what do you recommend the best fix is?
I'm tempted to silicone around where the glass and frame meet and see if that fixes the problem before replacing the extruded gasket at £25+
What do you recommend?
Julian
Julian
