LimL
This is from the suggested supplier’s description of the valve.
It is important that prior to purchase you fully understand the implications of a tap with this air gap.
This tap needs to be installed ideally with a pressure and flow restrictor (not supplied) inline before the tap. If flow or pressure in the system is too great or the tap sees back pressure in any situation then the DC Type anti-siphon adaptor will ‘leak’ through the side of the tap. This is normal and is doing what the device is intended to do. It means that whilst the tap has a hose tail fitted to the nozzle, it cannot be connected to any further device that attempts to control the flow further downstream. This unit prevents back pressure being created and therefore eliminates the possibilities of contamination of the water supply.
Use of this product will require the water flow and pressure to be kept to a minimum by the fitting of a pressure/flow reducer upstream of the tap.”
So looks not to be a viable solution for the intended purpose on the river. I suspect they will quickly “disappear” or be “modified” with tape around the barrel.
