greeny
Hi guys,
I'm normally on the sailing forums but thought this was the place more likely to have expertise in this field.
I was out in the rib yesterday, 20 knts, 4200 rpm when there was a sudden lock up on the engine. Then the starter then just clicked and wouldn't turn the engine over. I had to get a tow in eventually.
So today I took the top cover off to expose the timing belt and flywheel. With a spanner on the flywheel and no plugs in, the engine turns smoothly through approx 90 deg of its rotation then hits something solid inside. Rotate the other way and it hits the same solid stop. There is no "graunching" or scraping, it just stops dead at that point.
Took the rocker cover off and all seems good in there and all valves still there in place. I tried to put a cheap boroscope into the cylinders through the plug holes but couldn't see much detail. Shining a torch into the cylinders I can see a level of oil (I think its oil) in the no3 cylinder.
I've dropped off the bottom leg off and the symptoms are the same so its not to do with the gearbox.
At first I thought it was maybe the primary gear gone in some way causing the very solid locking up 90 deg apart. But now I've seen the oil in the cylinder I'm not so sure.
Maybe the only way to progress this now is a complete strip down but before I get get any deeper I'd just like to ask if there's any other ideas or thoughts out there that I might have missed.
Whilst I've played lots of engine years ago from cars, motorbikes, diesel generators and small outboards, I've not had the pleasure of one of these before and would like to ask advice first.
