eddystone
My Honda has an oil leak - it seeps down the leg and collects on the bottom. However when I look at the oil level it aways seems to be at or above the mark. Any obvious things to check?
HiMy Honda has an oil leak - it seeps down the leg and collects on the bottom. However when I look at the oil level it aways seems to be at or above the mark. Any obvious things to check?
Not the result of laying the engine down incorrectly , I suppose ?It’s coming from the top end - I will check the drain plug
That would just cause it to leak after the "misuse" event wouldn't it, rather than ongoing seepage?Not the result of laying the engine down incorrectly , I suppose ?
Just in case this is the issue with mine, is it possible to replace the rocker cover without removing the whole power head?HI , everyone here has listed correctly the main issues.
Usual culprit as Keith has said is a corroded rocker cover.
PS I have been reported for adverising on the forum again , if anyone is wondering where all of my float bowl messsges have gone to
Oh well - I’d better hope that it’s not the rocker cover then!I wouldnt recommend it. The lower bolts heads will be corroded and hard to reach and do tend to break
Thanks - do you know if there’s a guide to doing this on the internet?Yes easy enough, If you do have to do it , its important you reset rocker clearances, they do neez doing on these fairly regularly and are included in a major service.
I dont know any main dealers that do it as its a faff
