Honda BF2.3 oil leak
eddystone
18 Aug 2013
North West Devon
My Honda has an oil leak - it seeps down the leg and collects on the bottom. However when I look at the oil level it aways seems to be at or above the mark. Any obvious things to check?
Hi
There are 2 oil reservoirs.
One for the main engine.
One for the "bottom end" where the (vertical) prop shaft has a bevel gear, and transfers the energy from vertical to horizontal.
The bottom end has 2 bolts holding the plate in place, and there is a gasket between the plate and the bottom.of the leg.
It's possible your gasket on this lower end is leaking.
If it is , you can always get some gasket card and replace it yourself.
Just picking up on this thread - I had some dark oily streaks appearing down the leg, and it looks a lot like thinned grease that sits in the ‘swivel’ area. I wondered if it was a bit of fuel leaking from the carb and thinning down the grease.
I’m hoping it’s not the drain plug, as that has seized solid, and I’m now resorting to using the fill plug for draining!
HI , everyone here has listed correctly the main issues.
Usual culprit as Keith has said is a corroded rocker cover.
PS I have been reported for adverising on the forum again , if anyone is wondering where all of my float bowl messsges have gone to
Just in case this is the issue with mine, is it possible to replace the rocker cover without removing the whole power head?
Yes easy enough, If you do have to do it , its important you reset rocker clearances, they do neez doing on these fairly regularly and are included in a major service.
I dont know any main dealers that do it as its a faff
Thanks - do you know if there’s a guide to doing this on the internet?
Also, it looks like I’m still ‘locked down’ as a new member ref using DMs. I can’t find anything on the forums which confirms what I need to do to get this lifted. 🤷‍♂️
