beluga
Volvo 2003 Turbo 43 HP. Just changed fresh water pump and had to drain and refill fresh water system. now engine overheats. I think I may have an airlock. Did not seem to replace as much liquid as drained out. I have undone hoses in high and low places and water comes out. If it is an airlock I do not know how to get rid of it. The engine does have a hot water tank and heat exchanger. Sea water system works well. It also passes through an oil cooler. I have also changed the thermostat. I am cruising in South Biscay and am desperate for help. Thank you. Ian
