jaysparticus
Hi Folks. Hope your all enjoying the summer!
I have a new dilemma.
I have been out on the boat today - Seamaster 23 with a 1600cc inboard petrol engine - and after 30- 40 min the engine started spluttering and then stalled. i scratched my head for a while and changed the fule filter etc and checked the carb but everything seemed fine but i couldn't get it to start again.
After approx 45 mins i tried again and the engine started and sounded great again so i continued on my journey thinking that i had rectified the problem !
Again after 30 - 40 mins the engine did the same , started spluttering and stalled. I checked the temperature and it was 68deg on the engine and the oil pressure was 28 psi but the engine felt hot to touch... expected.
i removed the carb again and worked the accelerator and i could see fuel injection and atomising due to the heat.
I then thought i may have a blocked vent on my petrol tank and i removed the fill cap and went for a start and woosh it fired up! I believed i had cracked the problem. I had at this time altered the mixture screw etc in my efforts so the engine was running a bit rich .
The boat is putting plenty of water out the back too .
Off i went again on my travels and AGAIN... after 30 - 40 mins the engine stalled again after spluttering and i have the fill cap still off!! each time it takes 45 - 1 hour to restart as if it is cooling down or if the engine is flooded but i have used a colour tuner on the plugs and got it set up perfect.
The engine in essence is brand new and has recently been installed and did run ok but now it is a disaster as on the York river Ouse, the traffic is a lot for a broken down boat to take on!!
Any help and advice will be really appreciated
** if anyone know a good mechanic in york please let me know
James
James
