Quandary
First, apologies to those who think I should be able to find the answer using the search button, it gives me more information than I could read in a fortnight and only some of it is relevant.
Boat was launched this morning, started engine (Volvo D1-30 with saildrive and indirect cooling) Started fine but only the odd drip of water from the exhaust. Removed impeller which was in several pieces, seemed to have collected the right number of missing vanes but half of one might be missing. Replaced and tried again, but only a little more water. Checked primary water filter for air leak but cover seal seemed to be holding fine as it was hard to lift the cover. Tried priming pump by pouring some water into the filter pot. Noticed that a drip had started where the rubber water pipe was connected to the impeller pump suggesting possible pressure there. Moved jubilee clip and added another to the joint. I am guessing that a piece of vane may stuck somewhere it should not be, the pipe joints are murder to undo so where should I look first. I am suspicious that the blockage might be at the vacuum valve but have no reason for this other than a sort of optimism as I know nothing about heat exchangers and all the other pipe joints are hard to get at. If it helps when I undid the impeller cover the second time water was flowing into the bilges at a considerable rate.
Any other suggestions? The owners manual I have is useless for fault tracing, I suppose they expect to take it to a workshop but I prefer to try to learn how to solve these problems.
