ianainge
well what a disaster of a weekend,left hamble filled up with fuel ,two friends on board who wanted try wakeboarding of my Targa 31 .on circling around to pick on up after a wipe out i noticed a sooty black deposit on the water coming presumably from my exhaust , looked in engine room to find small oil leak coming from what looks like the oil cooler, not a seal or gasket leak but a hole which looks like it was caused by corrosion, anyway put an extra pint in, decide to put a cup under it and head for home.i dont think this problem is related to the sooty deposits as the oil is dripping into the oil tray and has no way of exiting the boat, also it appears from both engines not just one. 1 1/2 hours later the bilge pump light comes on , we stop the boat and find the bilge full of oil ,bilge pump clogged and after letting the oil settle dip the stick to find nothing in there.oil pressure remained normal at all times ,and no warning lights came on.Question is whats causing the sooty deposits, and is it likely ive caused any damage to engine, where can i get a decent priced cooler, a new one is £1500 are there any secondhand ones about. is this something i could fit myself (no real mechanical experience) or should i leave it to thr pro`s ?.engines ad41b`s diesel.
