send54sail
If anybody who has actually taken apart and serviced a Lofrans Project X2 windlass could give me some tips on the following I would be most grateful, having drawn a blank in getting any response at all from the sole Lofrans UK distributor (Peachment) and been unable to find any proper workshop manual (although there is a good parts diagram on the back of the instructions).
I want to strip down and replace the service items generally in the windlass so I got the service kit for the Project X2 but - before I start violently sprising corroded bits apart - there's a few issues I want to check with the experts:
1/ There are a number of items (seals, circlips, bearings etc) that slide onto the "standard shaft" (part 917) immediately on top of the "base" (part 904) (and then the cone clutch sits on top of those). The photo attached shows how that area looks before taking any of those items off so they do seem to have corroded away to nothing which is not too surprising in the case of flimsy seals and circlips but one of the items that should be visible there is a quite chunky looking "stainless steel bearing" (part 903) which also seems to have been eaten away to nothing (or possibly isn't even there at all?).
Lofrans don't include this bearing as a service item, so they must assume that these bearings will not normally need to be replaced. Has anyone come across this before and just from looking at the photo do you reckon that this bearing is in fact still there on the shaft but is corroded or do you think its not even there at all? Bit reluctant to sprise the corroded stuff off without knowing.
2/ I am also concerned that there is a spring mechanism in the works between the Gearcase upper (920) and Gearcase lower (928). I need to get inside those workings to replace several service items but I have seen elsewhere that a specific compressor tool is needed to re-assemble with that spring in the way. Is that correct? Is a special tool needed to do the service?
3/ The cone clutch (part 915 on the Lofrans parts diagram for the Project X2) has become stuck to the gypsy due to corrosion (which is fairly standard problem I believe) so I need to get those separated. Any tips on how?
4/ Last, the instructions say that the oil in the gear box should be changed but nothing at all about how you access the gearbox or what grade of oil is needed or in fact anything at all. Again, any tips?
Any insights very much appreciated - as well as the distributor not wanting to help, I also can't find any trades that actually service these windlasses or know much about them (although keen to sell me a new one) and my instruction manual doesn't tell me anything beyond the parts diagram.
Cheers
Andy
Cheers
Andy
