petem
Time to get those batteries charged up fully on shore power, if the alternator hasn't been charging properly.
Shorepower doesn't charge the dedicatd starboard engine starting battery.
Draining fuel into wines glasses. Now that is proper posh
Glad you got the issues sorted!
Champagne glasses, don't tell the wife!
My diesel is totally clear so to me that looks like a lot of stuff in the diesel especially if you have just cleaned the tank , fuel and filters so all should be totally clean.
Sadly I use a lot of fuel and in mallorca most places have a huge fuel turnover so maybe that is it. Others will have a view but to me that does not look that great.
Good news re alternator belt.
+1 (sub Mallorca for SoF )
Thx for posting all this stuff ,iam sure all the forum is willing you on and wish the very best to you all and the boat arriving safley in the Med .
However entertaining as it is this last episode with Jez .
But a loose belt --Crikey !
Setting off to sea in a boat unknown to you that's essentially been laid up without spare filters --eek ?
That's petty basic stuff -- written in every marine diesel engine hand book , RYA ,MBY and 100,s of Utube vids .
The locals will have your eyeballs within a week in the Med , investigsting --- fixing these calamities .
Acting /advising in your best interest ,get the team to do basic checks --MBY have some great engine vids ,from memory it's even a KAD 44 -perfect .
Fuel sample
That's contaminated for sure !
A few 100 L sucked through those filters will capture the crud ,this means regular filter changes even initially @ every fill up of 2nd fill up for a while .
Remember the filters have to deal with more than the consumption because a lot is returned in your case cleaner .
Keep dosing with additive too every fill up .
Pete 2x filters less than £20 ,additive same ish --say 3x£40 for 3 fill ups --£120 ---well worth it compared to grief with pump and injector woes + hassle .
When it's spotless then replace the engine filters before shipping off to the Med .
Fuel sample
Just for people's interest and amusement, this is the fuel sample taken from a boat THAT WE DIDN'T BUY. Amazingly it still performed as per the original spec on the sea trial.
Estimated cost to have the tanks cleaned and fuel polished was €5k.
And this is the latest bowl full of diesel I have just drawn from my engines, yuk!
Have been adding Marine 16 and changing filters for months now but I suspect I am losing this battle and will need to get my tank cleaned when we get back to Blighty in a few weeks!
Out of interest, would you mind letting me know who you commissioned to check your fuel system through please?
Thanks,
Andrew
Re the fuel sample Pete, assuming it was drained from the bottom of the pre-filters I would say that is not unusual on a boat of of that age.
Greg, you make an important point there. Yes, my fuel sample was drained from the bottom of the two pre-filters, where it had rested overnight. In fact, after a few minutes of being in the glass, the sediment settled to the bottom and was almost imperceptible. Unless you looked very closely I don't think it wold be noticeable in the bottom of glass filter bowls. And as Porto correctly points out, in 6 or so hours of running the 500 litres in the tank could have been through the filters multiple times as a result of unspent diesel returning to the tank (I could be wrong there).
If there was that much sediment suspended in the body of the tank that might be a different matter.
Eeek, that doesn't look good! Where's the boat based? How as the sample taken?
Our boat is currently in Hythe and google threw up SAL Marine in Lymington as a firm that would add inspection hatches, clean tank and polish fuel. As per my earlier posts, they checked the condition of the tank via the sender aperture and confirmed they looked OK. They changed the filters at my request (I'd have changed them at the imminent survey anyhow). the full job would have been about a day's labour @£55ph plus £200 for filter. All plus VAT I suspect.
Subsequently, the local (non-VP agent) engineer recommended SDM (http://sdm-fuelsolutions.com/ ) and said they were the ONLY company that he would use so they may be worth a try.
The alleged €5k quote was in Mallorca. You would be under £1k in he UK I'd have thought.
